SimonD’s workbench
Chris, Graham,
thanks both.
The “pot” on the most recent photos is in the same place as the curiously shaped pot on Dave’s earlier post, but is a different shape. I’m going to have a look through my books and see if I can find out more. Might get a chance tomorrow evening.
atb
Simon,
This link... GWR locomotive lubrication in the 1930's | Model Engineering Clearing House ... includes a decent photo of a pepper pot, also known as a vacuum relief valve; there is going to be one of those in the vacuum system somewhere. Until I started looking for the pepper pot on a 1366 class I believed that the valve was screwed into the top of the vacuum pump.... I cannot see it in any photos of either 1361 or 1366 class locos.
Scroll down web page for post on 27/04/2020
Rgds, Graham
Scale7JB
The middle pot is for lubrication, usually a 50/50 oil/paraffin mix, and the other two will be vacuum relief valves.
JB.
Chris, Graham,
thanks both.
atb
I should have added that both photo snips are preservation era.
J_F_S
Simon,
Rgds, Graham
Thanks Graham,
my understanding of that vacuum relief valve is that it is in the steam circuit to prevent the ingress of cinders etc through the blastpipe by the avoidance of a vacuum in the live steam supply when the regulator is closed. I'd have called it a snifting valve, but I rather thought they were much bigger - perhaps this one is used on the ejector supply? It looks rather like the valves that are fitted fore and aft on all standard GW cylinder end plates, which I took to be overpressure relief valves - if that is the case, it will make the engine rather freer running with regulator closed.
Putting one of these into the vacuum pipework would break the vacuum, as it allows air in through the holes in the cover, and the pressure differential across the valve head (which is hidden) pulls the valve open against the spring. This would not be helpful and I don't think it belongs on the vac pump.
We want something like this - the "bicycle dynamo" which is definitely a lubricator.
cropped from Dave's photo
