If I ever see this Pannier shall I see the dot punch marks on the slidebars to define the front and rear limits of the stroke? Used by the fitters to adjust the position of the pump head piston (so as to avoid the embarrassing crack from a piston in very close contact with an end plate). Please note the length of the fastening where the rod passes through the crosshead bracket, there is a bush either side of the bracket and the length of those bushes is adjusted so as to move the pump rod relative to bracket.I am hopeful that the wheels have the right stroke so the piston rod doesn’t fall out of the pump.
Decoder installed, along with speaker and front sandpipes and the hanger bracket for thevacuumair pump.
And it’s had its first run along PD loco front siding which at the flick of a switch becomes a programming track - and having checked that it responded to programming, I renumbered it 1368.
So far so good. Now last week, it had a very thorough running session on a Settrack oval on the lounge floor, and you’ve all seen it working well hauling coaches around the Folkestone club track, so why does it now run like a lame horse?
It appears that the con rod just touches the motion bracket, as you can see here. I can only surmise that the suspension has moved a little, perhaps it’s starting to loosen up.
This is not the end of the world, though it is a prize pain in the posterior as there will now have to be some dismantling, filing and remantling.
The other thing that is not pleasing is the sound - it’s not adjusted yet, due to the limp, but it’s far from pleasing. Don’t know if that’s a speaker problem or the sound box I printed for it, but it’s not good enough!
So a few steps forward and at least one back. Some net progress at least.
Once it’s done and dusted, its stablemate, which I built from an indifferent kit some twenty years back, will need a make-over.View attachment 227129
But that’s in the future!
(As an aside, the cylinders on mine are too bloody thin too. How difficult is it to provide a kit with the right sized bits in?)
Precisely!I am intrigued to see hex not countersunk heads on the crank pins. I guess, hex in an oversize counterbore leaves more space for the epoxy?
There, that's put the mockers on itPrecisely!
Slaters wheels seem to vary. I have had wheels with a counterbore & crankpin hole, and wheels with only the crankpin hole. In the latter case, I drill a counterbore. I then tap the wheels using a drill press, and screw a 10BA machine screw into the wheel from the rear. A drop of epoxy on the thread and then screw it in tight. The epoxy fills the hole, and hopefully some also finds its way into the thread. I’ve done it this way for 25 years, and no failures to date. Touch wood…
I should add, I use steel screws, and I’m running out. I do have brass CSK but prefer steel for such applications.
I have also seen CSK screws with a bit of wire soldered into the slot, and that then epoxied in the wheel. I’m sure that would work too.
I don’t like the use of 12BA screws in wheels, though they are fitted to thousands of locos, I’d guess.
I thought you couldn’t polish a Jobbie..![]()
This is wandering off in to the realms of water companies and Private Eye. Stoppit!I've seen one painted and face drawn on it, further detail is not required.
