They do look good from the photos - are they full depth?
This is just pushed in. There’s a very thin gap where the weight just doesn’t quite sit on the rim of the wheel.
As you can see, the back in nearly flush and a smear of filler would make it so
![image.jpg image.jpg](https://www.westernthunder.co.uk/data/attachments/226/226223-412fa636c09a8badf14f756a64ce0b32.jpg)
I need to do a set for the 48xx and the Manor.
I wonder about generating a parametric model that allows the weight to be defined by wheel diameter and number of spokes, but I think it might be more trouble than it’s worth as there are other variables required to fully constrain the design.
I think it’s likely to be quicker to just re-save and modify the existing design for each application.
