High-tech being of the essence, waxing spatulae have been pressed into service to make a soldering jig.
It’s stuck to the Unimat T-slot table with double sided tape, and it’s heavy enough to stay put. The piano wire spring presses the “leg” into the slot in the axlebox and the parts can be soldered whilst pressing the axlebox down into the recess - otherwise it tends to “sit up” at an angle which is not ideal.
And the first result - Chris’ pannier sitting on its springs for the first time. I’m delighted with the smooth running through my pointwork, CSB really does seem to work.
As expected, the loco is a bit nose heavy. Not much but it does look like the wheel rim on the front axle is slightly more hidden behind the hanging bar than the rear. Maybe a bit less than 0.5mm. It’s within the range of ballast anyway.
Next step will be pickups so I can actually run it.
That’s a load of repetitive, simple lathe work, and I don’t (yet) have a CNC lathe at home…
And then we’ll get to the tricky bit. Crossheads and front axle crankpin…
On Simon's build, isn't there scope to fill the bunker with ballast? ( just seen Pencarrow's post ) BTW, I prefer rectangular brass bar from Macc Models to lead sheet, etc. for purposes of adding weight. Looking at Simon's photo above, the beam is quite a distance from the top of the axlebox - I wonder if it is preferable to position the beam as close as possible to the axlebox top? The hornblocks/cheeks/guides from Invertrain don't have the obstruction that Slaters' do. If it works smoothly, then no problem!
Just passing through, but titanium is chosen for its high strength to weight ratio. It is quite a lightweight metal.It's definitely not an issue with the location of the spring supports, it is, I suspect, because the smokebox is filled with depleted uranium, or titanium, or frozen mercury, or something similarly and ludicrously dense.
Thanks Richard, you’re right of course, Homer moment, I meant tungsten.Just passing through, but titanium is chosen for its high strength to weight ratio. It is quite a lightweight metal.
But weren't the civils the bane of CMEs etc when it came to weight restrictions imposed on new loco designs etc?I'll forgive Chris, he's a civil engineer (I'm a "rude mechanical") and weight is not generally something civvies are scared of
It's definitely not an issue with the location of the spring supports, it is, I suspect, because the smokebox is filled with depleted uranium, or titanium, or frozen mercury, or something similarly and ludicrously dense. I'll forgive Chris, he's a civil engineer (I'm a "rude mechanical") and weight is not generally something civvies are scared of
I do have a self-seal bag of lead shot which fills the bunker. This will undoubtedly sort out the "concorde coming into land" look but it will probably sort out the baseboards too... Suffice it to say that traction is unlikely to be an issue.
It was all described way back on page 48 or so. SimonD’s workbench
Joking aside, there is a fairly good argument for not over-weighting locos. Ideally, you want the wheels to spin if it gets stuck, rather than cook the windings of the motor. The current through a DC permanent magnet motor is highest when it is not turning, ie, stalled. Some DCC decoders offer some kind of overcurrent protection, but a DC controller and less sophisticated decoders might well provide sufficient current to wreck a stalled motor.
And the reason the CSB wires are as high as they are is to clear the pickups on the rear wheels, which are tucked up high so they are not visible from behind. The clearance between the CSB wires and the pickups will be pretty minimal.
Richard,I have a packet of Slater's hornblocks but I am yet to try them. I am finding it really helpful to see what they look like installed on a chassis. Thanks
But I am pondering, if the front-most supports for the CSBs were closer to the front hornblocks, would this pick the nose up a bit?
Or even, remove the front supports for the CSBs and install new ones with a hole a little further down, i.e. closer to the bottom of the frames, to lift the nose?
