thanks StephenI have attached a pdf
I doubt that I can find the same thing again, though it would be nice! The photos in the Russell book show square mesh. I shall try to reproduce that.
cheers
As far as the SVR vehcle is concerned, it was probably still in the process of restoration. I bought the Blacksmith etch as I had used one on a B set, and have hopes of another one some day.thanks Stephen
cheers
Hi Simon , when i went back with your link i realised that i had read the cartridge paper part but had blocked out the 3d print . I'm thinking that there may be something to this 3d printing lark but would it get the use to make it viable , the jury's out on that .Hi Paul, roof here. SimonD’s workbench
3DP, cartridge paper, microstrip & 3DP ventilators. Permanent spray glue to put the cartridge paper on, cyano for the ventilators and to stiffen the paper around the edges, MEK for the microstrip.
and no, nobody would have commented, but I had noticed. I doubt it took half an hour to fix, shame I wasted half an hou doing it wrong in the first place, but on the other hand, I proved that I can make flat bar from copper wire and that it is a useful material, as when it’s been rolled, and stretched, its very hard, thus stiff, and ideal for things like, well, flat bars…
It is extraordinarily useful, provided you have, or are prepared to acquire, the CAD skills.
Like any versatile tool, it can be tempting to use it when something else would perhaps be better. Resin and FDP are different in their applications. I don’t think FDP is good for model parts that are on-show, but there are all sorts of hidden applications such as signal bases with servo mounts, roofs, brackets for baseboards, etc, for which it is idea. Resin is fantastic for detail, but generally is brittle, and is known to warp if not thoroughly cured. It is also possible to 3DP transparent parts.
Coupled with hobby-accessible laser cutting & cnc machining, we are getting to a point when pretty much anything can be made at / better than a commercial standard.
That's an interesting final point Simon. The difference in viability of home vs commercial printing. If an item takes 10mins to print and you can get a few £s for it then it's viable for both. If it takes many, many hours and with a high failure rate, then it's not going to be commercially viable but not too much of an issue for the person printing at home.
I suppose higher quality settings = more time printing, so again more viable for the home printer than the commercial one. This does however ignore that the commercial printer could well have more expensive, better and faster kit.
Do you want a drawing of the GWR one?Does anyone have a dimensioned drawing of a shell (roof) ventilator?
The ones I’ve made are just over 4.2mm diameter, and much nicer that the blobs of white metal that came with the kit (and a little smaller) but I’ve just found some moulded plastic ones that are 4mm
If some kind soul could point me in the right direction I’d be grateful
Thx
