As a former architectural modelmaker I am naturally interested, but I have to be honest the strengthening confused me at first, I thought you were making a library. (Not actually joking) Then I realised it's sensible but must be a lot of work.
I'm currently building a large warehouse in my Dublingham thread from cardboard. It's showing signs of sagging and needs remedial work. My buildings built to full Scalescenes spec have double layer skins and as such show no signs of sagging. My warehouse has been done on the cheap and so needs attention.
I've never used limonene, but clearly it's the way to go. I guess your method lends itself to keeping everything lightweight. Please keep posting and let us know if the sagging is kept away.
I don't think the old WT joke of nothing behind the tender is still current.
Tony
Good morning Tony, slowly working through the various questions from yesterday...
Interesting that you did architectural modelling as a job. Having town up on Airfix and Star Wars, when I was (much) younger I had a dream to be one of the people that made models for films. Obviously that never happened and instead I ended up being a Civil Engineer ("for civil engineer see boring" as the old Yellow Pages used to say).
In a way I'm glad the hobby never became a job, I think I would have hated seeing my work either blown up or ending up in a skip. On the plus side the civil engineering gave me an understanding of how structures work and how materials react to loads. I think that's a plus, but perhaps we're back to "see boring" again.
In my early years I grew up on Superquick card kits, and later made a few buildings for club layouts. In those days the club approach for any building of size was to build a ply carcass and then clad it with card and or plasticard finishes. I did make a set of cottages from a Downsplan from a card frame, with walls clad with plasticard and roof with card tiles.
In later years I have built buildings for many joint layout projects. These have ranged from small huts through to long industrial premises. I've also had to undertake remedial work to buildings by others to address splitting, warping and show damage.
Lessons have been learnt along the way. I know others have success with ply and MDF frames but my own experience has been that they are prone to warp, particularly if one face is clad with plastic and the damp works on just one side. I've also learned that heavy construction doesn't always equal strong and that each material type has pros and cons. The other big learning from many repairs is to think about access for future maintenance.
I'm always told when demonstrating at shows that plastic warps and isn't stable. I'd agree that it does if you let it, and if you either use far too much solvent or trap the vapour in an enclosed space. For me the beauty of using plasticard is the ease of cutting, the flexibility and the almost instant joins.
With regards to the 'bookcases', you're not the first to make that comment! The approach comes from learning that strength doesn't come from lots of layers (weight does) and laminating layers is a great way to start warping (got that t-shirt). Think of the perpendicular ribs more like H beams used in buildings, their strength comes from the 2 flanges being separated by a deep web.
Yes, it does take a bit of time to do, but I'm evolving methods to cut that down and am experimenting with spacings. The pros though are that it's easy to get in with the solvent, there's no vapour traps, it's light, and (if you clad the inside two) you end up with a scale thickness of wall.
Does it work and prevent warping. Well, time will tell, but there's buildings on Pencarrow that are 5 to 10 years old that are still stable and flat. There's also another building I got half way through applying the mesh of ribs and then left for 18 months. The ribbed bit stayed flat, the untreated section took a lot of time and effort to dewarp when I came back to the building.
I would say that this is an approach not the approach. Every building is different and one of the first things I do is to think through how I'm going to build it. Shape, size and the number/size of windows are big influences on the decision.
I hope that gives a bit of background.
