Looking at the early B&W photo in post #3,072 and if you wanted to retain a degree of authenticity of the relationship of the to the cottages to the track you could always lower their foundations slightly so the bottom window sill is at track level - cannot tell if this is already the case from the photo angles.
Having looked at the NLS 25 inch 1892-1914 series it appears the cottages follow the railway line boundary as is also evident in the photos. My guess is the cottages were built either at the same time or just after the railway built.
I also didn't realise the LSWR carried out some hefty earthworks and track realignment around Dunmere Junction.
Hi Dave,
The pink line in your map snip was the original alignment of the line to Bodmin Wharf when it was a freight only line. The LSWR acquired the line and after a while closed it so that the worst of the bends could be taken out so that larger locos and stock could run. They also completely redeveloped Bodmin Wharf to become a proper passenger terminus station - Bodmin North.
As you say, there were some pretty heavy earthworks involved, plus a financial hit as the line was closed whilst the works were undertaken. Can't imagine they got a huge return for this expenditure, more a strategic move to block GWR expansion...
Mike Walker
They certainly did and in addition to the Dunmere area there were major realignments around Grogley and between Dunmere and Bodmin. The original B&WR was built very early (1834) and had light rail, sharp curves and steep gradients. When proper passenger services were introduced, the line between Wadebridge and Bodmin was upgraded in the 1890s to take care of the first two issues although the gradients remained. The Wenford branch was never upgraded hence its reliance on the Beattie Well Tanks etc.
As far as I'm aware, the cottages, certainly the ones at Helland, pre-dated the railway.
Hi Mike, thanks for the comments. I was fairly convinced that the cottages predated the railway.
I'm quite pleased they never did much work on the curves up to Wenford... We'd never have seen the Beattie Well Tanks last so long and into preservation had they done so.
As a round up of the loco roster, I have...
SR
- BWT in flat-pack kit form
- T9 in flat pack kit form
- N Class in flat pack kit form
- O2 nearing completion by me
- 34066 Spitfire built by Mick
WR
- 1368 group effort build/rescue, me to finish off (thanks Simon D)
- 4666 RTR Minerva devil's pannier
- 4569 RTR prairie (needs renumbering)
MR
- Ivatt tank bought built
Smelly Diesel
- AC Railbus RTR
- 03 RTR
- Class 22 bought built
Currently contemplating
- BR Std 3MT RTR
In reality that's a few more than ran to the real Bodmin North but I've bent history, so nurrrrr.
Very noticeable how RTR favours WR and BR smelly diesels in terms of locos than ran in the Wadebridge and Bodmin areas....
I was the +1 helper yesterday assisting Mark with his P4 layout at the DEFine one-day show near Derby. Came away inspired to do some work on Pencarrow.
Doesn't look much but it's taken quite a lot of head scratching, measuring and numbers on scraps of paper to get this far.
PXL_20250112_155532197.jpgPXL_20250112_155537667.MP.jpgPXL_20250112_155543905.jpgPXL_20250112_155550140.jpg
Always tricky getting arches to form nicely and then stay arched over time and not detach etc. Hence the many formers.
Yes, the bottom of the arch is still tied together. This will aid marking up the arch rings, plus prevents the arch spreading when being built.
The baseboard 'ground' in this location slopes in both directions, so the laser level was used to get a datum horizontal and vertical line when marking the bridge up before cutting out.PXL_20250112_160728165.jpg
