Horns. Objective is to get them fixed to the chassis, in the right place is nice, but at the right spacing, and with the axles perpendicular to the chassis is vital.
First pair fitted, it’s a bit fiddly but does not require five hands. The 13” length of silver steel is ideal to set them square on. I had filed the openings a little too wide so there’s scope for adjustment. If you’re better at filing than me (and your chassis isn’t already assembled) then you might get them to be a tighter fit.
The spring keeps the hornways pressed gently in place, once everything looks right, clip on with forceps, tack solder, check, remove dummy axle and axle boxes and use gas torch to complete the joints.
First pair is critical - could be the middle ones, or either end. It’s set up on a piece of plate glass, I think it was a shelf from a TV cabinet or something - it’s 1/4” thick and dead flat.
Now the fun starts. A set of these is what you need
These dummy axles have a gentle taper at each end 2.2 out to 2.8 diameter - the holes in the coupling rods are 2.5. Length doesn’t matter, though it’ll help if they’re all the same!
One through each pair of axleboxes, fit the rods on the ends, ensure everything looks right, tack solder. Then fit the wheels and see if it runs.
It does - first time
Then finish solder and scrub up.
Or not
Once I got it all together, I noticed that the rear right hornway was not quite upright in the slot I’d cut. This was one of the first two I’d done when I was setting everything square. Hopefully I can fix that without making it run like a lame horse…
Looks better.
There’s another snag. When I built the loco, my first, I used the 12BA screws and nuts supplied with the wheels. The only one I did, as for all subsequent locos, I’ve tapped the wheels and the crank bushes 10BA, and epoxied steel screws into the wheels. Now I’m sure that 12BA is strong enough, but the rigid stamped rods that came with the kit were much thinner than the jointed Premier ones I’ve now got, and so the screws are too damn short.
Looks like I have two choices: they’ll have to come out and be replaced with longer 10BA screws with my usual threaded bushes, or I’ll have to spend stupid money on a 12BA tap in order to turn up some threaded 12 BA bushes as I broke my last one.
I guess a bit of heat would get the screws out of the wheels - but can I do it without wrecking them?
