Not feeling the vibe for risking APOC transfers tonight, that'll wait for the weekend. Meanwhile, more little panniers.
I think we have a route to a chassis... Premier frames, 28mm over the outside (or very close). The cylinders were drawn to scale, but of course over the frames, the real beast is a bit wider - 4'1.125 between, and frames 1.25" thick,(assuming I've read the drawing correctly) comes out at near on 30.1 - so they need packing out by a millimetre each side - or reprinting slightly thicker - I 'm inclined to use a 40 thou plasticard packing piece and I can hear the S7 guys giggling to themselves and saying "told you so" from here
Next question. suspension.
Options are:
A) rigid. No, no, and thrice no. well, maybe. but no.
B) sprung with coil springs. Mine is sprung this way and was a complete PITA when I first built it (some 23 years ago) as it did a credible impression of a nodding dog on starting, and particularly on stopping. Sorted it eventually but don't want to do that again.
C) compensated. Milkmaids have, as I have earlier remarked, three legged stools, because they don't wobble (the stools, the milkmaids may wobble if they wish, who am I to stop them). Agenoria* panniers are provided with 4 legged compensation which isn't compensation and doesn't, indeed, can't work. 3 legged is possible. Possibly double beams at the rear, and the front axle with a centre fulcrum. (* before Andy Beaton took it over.)
D) CSB. Never done it. Should be possible. Interesting.
Need to consider position of CoG. The body is weighted, indeed, I think our Pencarrow has a supply of depleted uranium or something.
It tips the scales (and will likely flatten your track) at 679g of which 403 at front buffer beam 276 at rear. CoG is therefore 64mm from front buffer plank, which is pretty much directly under the dome, and about 11.5mm ahead of the driving axle. And it will get heavier, of course. This is a good reason for not compensating it with a rocking beam between the middle and front axle. The CoG would be only just within the triangle and a bit of excited cornering might be destructive and possibly spectacular.
The very tight clearances behind the crossheads mean I do not want the front axle to rock much, it'll need to move a bit, but only a bit...
Not wild about Finney hornguides. Might go Slaters.
I shall consider further.
Right, that's it for tonight.
