Heather Kay
There will be quite a lot of it
What about that self-adhesive aluminium tape that builders use? It’ll be a bit harder to paint, but you get lots of the stuff on the roll.
I’ve a feeling it might be a bit too thick
I can’t speak from personal experience, but a lot of the aircraft modellers use it for adding panels, and even for a shiny natural metal finish. I think the stuff I have in mind is quite thin.
Thank you both, if someone would tell me how thick it is, and a brand name if possible, I can go & get a roll
cheers
Well, I’ve been playing with the laser again.
On t’other channel I posted progress on the locoshed roof, it would be fair to say this did not attract universal approval, so some further work was required. Now done, the kerf that the laser produces is a bit wider than the proper gap should be, but it is what it is.
Flashing required, foil seems favourite, a suggestion that only that which covers the corks on fine wines would be best.
On another subject, anybody remember Peco Wonderful Wagons?
I rather fancy a decent meat train to go behind my 47xx, but the wagons are a price, and a “decent meat train” would require quite a few. I have two Parkside and a WEP, but three wagons does not suffice. Even with a toad.
So I posed myself the question, can I preprint card sides, laser etch them, and cut them out, and fit them to a cheap, dimensionally stable “box”. Presuming that handrails, locking bars etc can be appliqué or poked into holes as appropriate. And if so, can I mass produce the van bodies for my train?
there’s still the matter of chassis to be addressed, but I’ve made some progress on the box (easy) and the roof (we’ll see).
Roof jig
first off roof, three layers laminated card. Close but no cigar, yet...
Shame, I was rather pleased with the jig...
A little further work will get us over the line, I hope.
(The other side isn’t as straight...)
thoughts?
Interesting, and something that I've been thinking of using for flashing.
I note that it's very stick - any top tips on how to cut thin, shaped pieces without getting totally stuck up?
