Thanks Dave.
I bought my laser second hand from the wife of the Godson of a mate…. It’s a Chinese-made 40W CO2 device, and had been “Europeanised” a bit. It depended on a truly awful software interface which I think was called NewlyDraw, and whilst it worked, it was clunky and awful. Probably ok for doing pictures on drinks coasters, but not much use for modelling.
It was one of these
LS3020 Desktop CO2 Laser Cutting Machine by HPC | HPC Laser. I paid £300. I rather think HPC do a better job than whoever sold mine originally. You can probably buy the same unit on eBay if you search. Eg
(it’s the same machine!)
It had no limit switches, so I fitted them, along with an interlock on the lid, and a flow sensor on the cooling water and replaced the control board with a Smoothieboard, and purchased a Lightburn licence, it’s now reasonably reliable and accurate.
Cooling water? Yep, CO2 lasers need a tank of water, and an aquarium pump to keep the discharge tube cool.
Ventilation is another requirement, i tried a bathroom extractor, but it was predictably useless, however, a mate turned up one day with something that’s far too large, (I think it came off an SRN6) but which works brilliantly, and I use that.
There is a thread on RMWeb -
CO2 laser - the learning curve
I would not repeat the experience, having learned a bit along the way!
I’d certainly go with a diode laser (and will probably fit a diode rather than fork out for a new tube when the current one dies) and if I were replacing the controller, I’d use a GRBL as they’re cheaper and more generally available than the Smoothieboard.
if I were starting from scratch, I think I’d probably look at Emblasers, and similar flat table designs, but my intention is eventually to have a high quality XYZ table and simply change the head to allow milling, engraving, laser, rivetter, whatever I wanted to do. Haven’t got there yet. In any case, whatever you do will need an enclosure, both for your safety, and to allow the extract system to vent the smoke.
A number of WTers have lasers, I think
@Giles and
@adrian and I’m sure there are others. And Phil
@BrushType4 has a business laser cutting stuff, so you might want to ask a few more opinions.
Obviously, you’ll need to generate the CAD files - lots of options there, I use TurboCAD because I've had it for years.
HTH
