spikey faz
Those hornblocks/guides look good. Do you mind me asking what make they are, as I might need to obtain some.Iteration 926 of N6 loco coal is printing…
Meanwhile at the grubby bench, a step forwards. The laser cut slidebars are soldered together and partially cleaned up - don’t use a blow lamp, it’s far too harsh, indeed, the hot air paint stripper was also OTT for soldering such small parts, so I reverted to a decent chunky bit on the Ersa which is what I should have done in the first place.
Ho hum, it’s a learning curve!
Quite a lot of fitting required to get to here, but I’m quite pleasedView attachment 207592View attachment 207593View attachment 207594
as I think this looks quite good. Particularly pleased to see scale width slidebars, rather than the undernourished etchings supplied with the kit.
I think I’m going to redo the motion brackets, in two parts screwed on from the outside, as the one-piece one does not work well with the slide bars soldered to it and then fitted to the cylinders as the cylinders have studs (with nuts) to attach to the frames as you can’t do up screws from the inside. In effect, I can’t assemble it as it is - cue Homer-style “D’oh!”.
I shall consider this further before proceeding.
It’s probably difficult to see in the previous shots but the coupling rods will need to be recessed to sink the crankpin head into the thickness of the rod. The head of the 12BA screw will definitely not fit. I had to do this on my own 1366 so I’m not really surprised.
Obviously all sitting in place, nothing fixed as yet. The flange on the rear of the crosshead needs to go where the washer is…
More soon
Thanks
