As it’s somewhat displaced at the moment, herewith a few photos of the locoshed. I decided that looking balefully at the uncompleted roof was not going to get it finished, and I have too many half finished, even half baked projects on the go, so a little uncharacteristic self discipline...
firstly, the underside:
the side you don’t get to see
With the workshop & office propped into place
I haven’t started on the roof for this yet. It’s part glazed, part slate.
the hole in the baseboard - yes, I didn’t think about the pits when I designed the baseboard, so it is not exquisite under here. Move along, nothing to see here...
rather a lot of scenicifying required round the back....
and the roof:
Which now has lights. I need to paint the light wires & resistors black, and fit contacts on the roof that will collect the lights’ power from the two lengths of aluminium angle that are epoxied to the top of the walls to stop them bowing inwards. I’ve just fitted two copper wires up the inside of the walls, which will be retained to the ally with 10BA screws, you can see the wires going to the connections on the first photo. These will eventually be suitably disguised as conduits with appropriate switch panels.
To complete the roof, I need to finish & fit the smoke hoods, I made the clerestory vents last weekend, and I purchased some 0.5 and 1mm PETG sheet from Kitronic, which is the same stuff that Tim W used for the glazed gallery he’s doing for Copenhagen Fields. It’ll look better than the 1.5 mm acrylic.
Slates are laser cut in strips from a slightly metallic grey art card, over sprayed with grey, purple and green washes, I need to mark out the roof so they get fitted in straight rows!
At some point I need to glaze it. That’ll be a laugh, not. There are 240 main panes to fit, 3 larger ones, and 96 smaller, plus the glass either side of the smoke hoods over the doors.
I have started the artwork for the etched door hinges and roof walkway supports, so I’ll get that finished and off to PPD at some point.
if anyone’s got a Dean goods boiler they don’t need, I have a home for it, under the very tall chimney!
more soon
