How long before Mrs Pencarrow takes ownership ?
Would it be wrong, do you think, to fit a lock on the train room door?
Chris, how long is the space for the fiddle yard? I’m just trying to assess what length trains you can run. Anyway, it all looks smart with plenty of storage for all those unmade kits.
Inside or outside of the door?
1.350m which is about 4' 6". Obviously it would be good to have a chunk more, particularly for the goods trains but walls sort of stop that ; -p
Trains won't be much more than a loco, pair of coaches and a van.
Back date a little the stock becomes shorter.
Well Chris you have prompted me into buy storage trays & boxes for the man cave yesterday
as for fitting a lock you can use the excuse it will keep to young one's out of the room when
they visit.
Somehow the space is 50mm longer than I was expecting...
Very nice, I need some too. I see CRT now do brass Maunsells at £175. I wouldn't mind getting a P set from them. How they compare to Slater's I don't know.
Don't forget you will need a bit of wiggle room to separate the boards when you are installing or removing them. I found this out the hard way when I tried to set up my 12ft long US layout along my 12ft long bedroom wall.I just manage it by removing the end backscene boards which just gives enough room to clear the dowel pins on one end board which is enough to get all the boards on and off.
Jim.
