I presume the fault was that the sides were not straight because the mathematician in me wants to point out that if the sides were straight and the diametrically opposite corners are right angles then by the rules of geometry the parallel sides must be equal in length and the other corners must also be right angles. The only condition where the other corners cannot be right angles is where the sides are not straight. (apologies for the interruption it's one of the problems of both parents being teachers!)![]()
Well I can confirm I don't have that problem. The only right angles in the house are in the extension (which we added)...as are the only verticals and the only flat bits.
The carpenter in the original build obviously came to work pi55ed, had no level, square or tape. He did have big chunks of timber (which is a good thing for stuff like floor joists etc) and certainly enjoyed wacking great big nails by the hundreds into the house.
Don't get me started on the plasterer. Amazing how vertical block and brick can be turned into non-vertical and non-square.
Most of the way through the referb, 'just' the upstairs rooms left now.
?) and with 2' thick walls to boot. Although there's not a vertical interior wall the interior door jambs are square as are the exterior windows. Obviously the workmanship was better 175 years ago
