This all looks very nice, Chris.
I think the key moment will be the removal into cupboards and behind doors of all the loose stuff on top of the layout.
Once clear, you should play trains for a bit, even if all areas not powered as yet..
Perhaps you could sit and contemplate the layout with a glass of port. I am a fan of contemplating with port. Some of my best port has been had whilst contemplating.
Rob.
Chris as you have put the cupboard units onto carpet have you connected them
together at the front ? I use to when installing a kitchen as a matter of cause,
screws can be hidden under the hinges to make a smart job clamp the cupboards
together and drill a pilot hole where the screw is going to go and use a 1" screw and
make sure you have set the legs so the kick panel fits before loading with any weight.
(offer up the screw before driving it in to make sure it's not over size.)
Kick panel will have a slight gap at the top 2-3mm to make getting them on and off easy. Space under is earmarked for safely storing out of harms way some long items needed later in the build...
Do you need to put the doors on?
Port bottles are quite long.........
Chris, maybe worth noting what you eventually put in the cupboards as we all know that its difficult to find stuff when its tidy !
Hi Bob,
The first three units are screwed together as you suggest. The rest will follow suit over the next few days. They sit in industrial grade carpet tiles which don't have much if any give in them. Kick panel will have a slight gap at the top 2-3mm to make getting them on and off easy. Space under is earmarked for safely storing out of harms way some long items needed later in the build...
Ah, yes, a daughter. Useful.
MissD was very helpful building the understructure for PD, and whenever I needed to pull it out for access behind. Trouble is, she’s now gone off to study, so MrsD will have to help when I get round to doing the scenic towards the back of the layout.
And the downside of that is that all the furniture needs to be moved, so she’ll have to sit in chaos whilst I fettle, make a noise, and make a mess. I was inclined to do that whilst MrsD was out, and MissD was inclined to disappear off to her bedroom, once we’d totally devastated the living room, so didn’t mind...
I also buy the multi packs of new Chinese-food containers for smaller items or open packets of grass/ ground cover.
These both stack well and do help to find stuff.
Sometimes.
Sounds like you need to move family and non-train content out of the living room Simon. Says he that's moving domestic stuff into the train room)
I think I just thank my lucky stars tha5 MrsD is as accommodating as she is, and I continue to refrain from machining things when she’s watching telly...
