HI Chris,
It was great to see you and Sheepy, today. I have to say that the layout looked good, even if it was full of garden sheds, although they do have some character.
Keep bashing on with Bodmin, at your own pace, it would be a shame to waste all that great modelling.
And the sheet store photo obviously using 4mm rather than 7mm plasticard...
.......it's one for 1st April..... sheet styrene available in 7, 4, 3.5, 2.5 and 2mm scales. Good job I've been using 3.5mm scale styrene sheet for my HO modelling
.Didn't know there was a difference.......it's one for 1st April..... sheet styrene available in 7, 4, 3.5, 2.5 and 2mm scales. Good job I've been using 3.5mm scale styrene sheet for my HO modelling
Obviously the sheet store is designed fit in with their modular system and they clearly hadn't thought about A3 styrene sheets. Knocking out one of the rear side pockets would have solved the issue. Also looks the same with the shallow tool tray in the top of tool tidy - two instead of three trays would have been better.
Interesting though as A4 is 297 x 210 mm and the store is designed for sheets up to 222 mm wide?
Needs some sticky back plastic.
