As well as the courtyards, I've been making a start on the roofs. The main profiles have been added - that's another sheet of plasticard gone.
I then started thinking about chimneys. I want these to be part of the roof structure and not added afterwards. So a bit of planning involved and thinking about construction sequence. But first a bit of fag packet sketching:
Two different heights, four different depths, same width. Plus a reminder to self that my two outside stacks will be different to reality as I've tacked the newer building on the opposite end.
A few photos from GoogleEarth of the remains of the real chimneys....
![rps20230319_094549.jpg rps20230319_094549.jpg](https://www.westernthunder.co.uk/data/attachments/182/182766-aa09964d74fec841c66eebb66c5771e8.jpg)
The 4 potter which is at the lean-to end, but which needs to be a 6 potter on my model.
![rps20230319_094719.jpg rps20230319_094719.jpg](https://www.westernthunder.co.uk/data/attachments/182/182768-80504c61c858a6372cf0836ab5c1c380.jpg)
The 2 potter which will stay as is.
![rps20230319_094655.jpg rps20230319_094655.jpg](https://www.westernthunder.co.uk/data/attachments/182/182767-2b84351c45429931737326546ff9b7ff.jpg)
The 5 potter (one missing) with added seagull which will stay as is.
![rps20230319_094742.jpg rps20230319_094742.jpg](https://www.westernthunder.co.uk/data/attachments/182/182769-73cf9286cd7f50d5c52f0371fcf96069.jpg)
The somewhat knocked around and decapitated 6 potter which will be a 4 potter on the model.
I've made a start on the 5 potter first, just to sort the method. It's made like a glove and fits snugly over the roof former. The coursing at the joins needs adding after the solvent has set.
And on place on the building. Not glued yet though.
From left to right in the above photo, the chimney stacks will be:
- 4 potter tall
- 5 potter tall
- 2 potter shorter
- 6 potter shorter
