Hi John,
There is a BG at the NRM - in LNWR livery! Hint... hint... you know you want to.
The EZ-build sides are extrusions so a section through a side is fairly constant throughout the length of the side... and that section is pretty well the same for each kit. The ends are mouldings and there can be some variation in the size of the moulding (dependent upon factors outside of our control). So if the side does not match the end as supplied then either remove or add some material to the end and then file / sand to fit.
The plastic used for these kits is ABS so Slater's MEK-PAK does not work very well, I have used Plastic-Weld for our model.
There are some dimension issues with the "U" parts of the underframe truss as supplied for the long underframe of the passenger coaches, not sure if that problem crops up with the short underframe as used for the BG. Maybe Bob Reid can comment on the suitability of the relevant depth dimensions given on the drawing in Mk.1 Carriages (Parkin, HMRS). Our Mk.1 BFK underframe has had the parts modified as in this
post.
Please post a photo of the etches so that we can see which V-hangers are included in this kit.
Exciting stuff John
regards, Graham
