What a delightful engine (the LNWR ST).
I have one to build (probably S7) when I finally pluck up the courage - care to reveal any areas that might warrant extra care for the unwary?
This was an easy build. The things to look out for:
There are no assembly drawings - typical for this designer - so there was some guesswork involved in fitting the coal plate. I am going to produce a supplementary set of instructions with photos to help the builder.
Parts 23 (frame extensions) and 24 (reach rod) don't exist on the etch but are simple to form from scrap etch.
Part 19 (left hand cab sheet beading) is wrong-handed. I simple cut it at the angle and made good the joint with solder.
The front guard irons are too long and the rear ones too short. I shortened the front ones and am living with the rear ones.
The brake handle shaft is too short. I cut it off and used a length of brass tube as a replacement.
I never enjoy fitting splasher tops and this kit was no exception. The instructions say to fit them inside the splasher sides but it might be easier to fit them to the top of the sides. They are long enough and wide enough for this. I did fit them so they are flush with the top of the sides and chamfered the ends of the splasher tops to blend in with the running plate. The joint is covered by the end plates.
We don't pack brass chimneys and domes (yet) with this kit. I had the delightful original chimney and dome LG castings in my bits box and decided to use them.
Next job is to shoehorn speaker, stay alive and DCC into the boiler.
David
