So back with the comforts of home, the Gladiator kit packing is complete and I have been able to pick up the building works.
The big brake van just needed a brake shoe. Simple.
The OCT took longer than expected as it suffered some damage in transit but is now ready.
Fortunately the Standard 5 was unharmed and has now had the final bits fitted.
So today it was back to the Jersey Lily. At 09:00 this morning I confidently expected to have the chassis completed and make progress - perhaps even complete - the body this afternoon. Well at 19:00 I still have the sandpipes to fit...........
On Saturday I had spent a couple of hours with the crossheads and slidebars getting a nice smooth sliding fit. The first job planned for this morning was to fit the con rods. The kit provides steel rivets and a suggestion to glue the rivet into the crosshead. I thought that a better solution would be to drill and tap the crosshead 14BA. The crossheads are cast in this peculiar composition of nickel silver that is next to impossible to drill (I am in the process of moving all nickel silver castings to another supplier) but I only broke one 0.8mm drill so I thought that was a win. Next up was to get my high quality 14BA tap and form the thread. Disaster! I dropped the assembly with the tap in it and the end of the tap broke off in the crosshead. I checked the price of a replacement - £64.30 plus P&P - ouch! So next job is to get another crosshead from the stores and match that to the slidebars. Next problem: the slitting disc broke as I used it to release the casting. It was my last one. So out with the saw. I broke the expensive Vallorbe blade. Now at this point I am beginning to think that a day in bed is a better option, but I carried on. Then with the crosshead nicely fettled I decided I just needed to tweak the angle of the head to the piston rod. You have guessed it: the rod broke off, so it is back to the stores and dress another crosshead.
Now some better news: there was enough left of the broken taper tap to thread the two crossheads and I managed to solder the screw in place without soldering up the con rod. So pick ups fitted and the only thing left on the frames now are the sand pipes.
![IMG_5116.jpg IMG_5116.jpg](https://www.westernthunder.co.uk/data/attachments/194/194141-7ec1fc4525e928602f1cb9e3cab90594.jpg)
