oldravendale
Just out of interest, Dave, when you come back to the UK do you hire an air freighter?....
Brian
Brian
No, but I’ve got to the stage when I think it worthwhile forking out for business class. With the frequent flier card it gives me 80kg baggage allowance, which is usually enough!Just out of interest, Dave, when you come back to the UK do you hire an air freighter?....
Brian
PeterNice work David.
Good to hear the mojo is firing up.
Is the smoke box flared at the front? DJH castings are not always what they are cracked up to be. The chimney could do with a couple of strokes from the file to remove the "capuchon".
Peter
Probably not a lot of help now that you have added the details, but I have had success using Milliput to fill porous whitemetal castings. Apply with water and it will fill the cavities without adding thickness to the surface, with no sanding needed afterwards. Usually on low volume car kits and similar rather than DJH.I had toyed with rejecting the smokebox casting. The jury is still out. Let's hope Paul Moore has some thick paint in his palette!
Dave,David.
On my 4 mm scale BR Std 5 (Caprotti version), I fixed all the RH pipework to the chassis, rather than the body, for the reasons you've discovered (although, in this case, there was the added complication of the exhaust steam pipe passing through the lubricator support bracket).
Might that be an option for you?
Dave.
I'll check for it in my workshop when I get out there later today.Missing buffers (to be replaced by Gladiator lost wax brass castings) and steam and vac pipes. The vac pipe pinged off and despite an extensive search of this quadrant of the galaxy has so far eluded me.
Brian,I'll check for it in my workshop when I get out there later today.
Brian
