Still no decision on whether or not to get out the gas axe for the water scoop.
Back to the loco: I managed to break all of the 0.5mm drills that I brought with me drilling out the various castings that need pipes attaching, or in the case of the cylinders, wire inserting to represent rivets. So it was back to the area next to Taipei Main Station, where in the same shop that I bought the M2 taps I was able to find a supply of small drill bits. So I bought up the stock of 6 0.5mm Japanese made drills at the equivalent of £1.50 each, which is about 50p cheaper that the German ones I get from Drill Service. I have to say that these Japanese ones are fantastic. Very sharp and cut quickly. I may have to go and buy up a few more of the small sizes before I return next month.
I built the bogie and wondered why I couldn't find the axle bearings. Well, I have also brought with me the Fowler tank to complete and I had accidentally put the bearings in with the bag of parts for that kit. That was not really a problem, until I discovered that I had also mixed up the supply of M2 nuts and 10mm M2 screws with the 8BA nuts and 10mm 8BA screws.......... So that was a frustrating hour spent sorting these. I will not be making that mistake again (I hope).
I decided that I ought to get some of the upper body structure formed before completing the frames. I need to get this right for the extensive pipe runs and I have got to the point on the frame assembly of locating the injectors and water valves. First part of the body assembly is the cab. It took me all weekend to get to the stages shown in these rather poor photos.
In case I haven't mentioned it before, the instructions leave something to be desired. The drawings and photos are very good but there are some key points that are not mentioned in the text. In the case of the cab assembly it is that there are two floor supports which need to be folded and positioned at an early stage. The written instructions do tell you to locate the cab rear before fitting the floor. I wasn't sure this would work, but it does.
Generally the fit of parts has been excellent. The exercise in origami that is the cab works quite well. But there are some parts in whitemetal that would be much better in brass. I think that the whitemetal casting in the last photo may be a slacking valve. Trying to locate this in place and then add three pipes and two control wheels was a real pita. If it had been brass then soldering would have been easy. I didn't want to risk soldering on such a small part so out came the Loctite 460.
I have built up the roof, side window frames and dragbeam assemblies. The windows probably need fitting after painting. I'll fit the roof now if the backhead will fit with it on.
