Pencarrow is based on a much compressed and rearranged version of Bodmin North. A few bits are fairly accurate but much of it falls more into the 'inspired by' category.
The lack of a 30m long space to do the job properly to scale does mean I've made some serious compromises along the way. Tony Wright wouldn't be impressed with the amount of compression used (or the fact I've not built a BR(E) mainline ;-p. )
As a result of my crimes against prototype fidelity there are a few areas I've struggled with getting to look right. One if these is the rear left corner of the layout where a lack of board width means that the bank, wall, road and buildings behind the yard can't be fitted in and there's a length of the layout between the grain store and the provender stores that ends too abruptly for my liking.
I've been mulling this over for a while, and perhaps for a bit too stuck on trying to make prototype features fit. Reality check, I'm building an 'inspired by'! With that in mind I've been looking for something to better finish the rear of the layout.
Flicking through books I looked again at the old Bodmin Wharf, the old B&W goods only terminus before it was rebuilt as a passenger station by the LSWR. The buildings below were a key part of the wharf but we're demolished by the LSWR prior to the new station layout opening on 1/11/1895.
These same few images are in just about every book and website covering the B&W.
So I decided to draw them up using a range of things to scale them such as the wagon wheelbase and height plus a guess at the height of the people in the photos. The full run of buildings is a good 40% too long so some amalgamation of the key features into a shorter set was undertaken.
Still some tweaking on the height of the ground the buildings sit on (a tad higher) and their orientation but I quite like them. The back story is that they, like the grain store, we're originally rail served prior to the site being remodeled by the LSWR who lowered the track levels - hence the buildings need to be a little higher.
There will be a path leading down to the station yard which runs between the grain store and the wharf buildings. Hints of a road will be visible behind the buildings.
One interesting element will be trying to guess how the buildings would have looked in the late 50s / early 60s period I'm modelling. That's c65 years after they were demolished. I doubt the bay windows and nice glazing would have survived...
I'll leave the drawing in place a few days to see how it sits with me.
