I was under an impression that multiple motors would confuse a single decoder. Just curious if that's a real issue, or simply a myth
Possibly if the motors are wired in parallel rather than series.
Will your decoder of choice for the U23b employ BEMF?
The decoder for the U23B will be a Loksound - which one? I don't know yet. I'll use BEMF but my experience with coreless and low current modern motors means this will be turned down quite far.
Rather than two Canon 1833's I may use two 6v coreless motors which will be wired in series, as Jordan does with the motors is his locos. As there is only one set of feed wires to the motors I think the decoder will interpret this as one. Like Jordan, motor matching to me is a relatively dark science - mainly because I haven't delved into it too far....yet.
I generally settle on Loksound decoders as:
a) I have a Lokprogrammer.
b) I can manipulate the sound files to my requirements/taste.
c) ESU has more open source downloadable sound files than ZIMO.
d) You can adjust the motor control parameter CVs to match the motor(s) to get the really fine control (ZIMO also).
e) I've had more experience with them.
With the big Pittman in the GP9 and the Loksound v4 L it'll be an interesting exercise - in at the deep end as I've yet to program a v4 decoder
![Eek! :eek: :eek:](/styles/default/xenforo/smilies/eek.png)
In my experience the Tsumami sounds are good but the decoders just do not have the sophistication of ESU or ZIMO when it comes to adjusting the motor control CVs. I found this out when programming a Tsunami in an Atlas HO CN C424.
