Well, until today I still had
trouble with the drive in the 70T which was on the verge of becoming
a Pachyderm Blanco
One of the trucks with the flexible coupling drive was perfect. However, the other was an absolute nightmare
and becoming a bit of a Debbie downer in danger of scuppering the whole build
So it was the last resort. Call it The Great Escape, Escape From Alcatraz or just plain last chance saloon....... it was back to the original plan - not for the purists though - of using the drive system from the 4mm Bachmann AL1 which has the correct wheelbase for the 1:48 GE 70T truck
First was to strip the trucks of their original wheels and ream the final drive gear to 2mm. New axles were cut from 2mm steel rod and the gear, nylon washers (to reduce side play), the original bearings and 2mm i/d to 3mm o/d brass tube were installed. The steel rod was knurled for the gear and brass tube. Once on the axle, the brass tube was knurled before pressing on the wheels as 3mm is just a gnat's whisker shy of 1/8''. I also used a retaining compound during fixing - apart from the bearings of course.
Mounting brackets were made up from tapped brass tube, some scrap brass and an outer sleeve on which the bracket rests.
Trial fitting of the Taff Vale 1833 motor.
Broadside view and, again the propshafts are hidden within the sill.
The trucks have keeper plates for which I shall make up a brass structure to attach to these in order to support the truck side frames and brake gear.
Although the axles appear flimsy, only time will tell if the weight of the loco will bend these in the style of the old Matchbox cars I used to have.
In the meantime the loco drives smoothly (under analogue control) to my satisfaction which has provided the impetus
to complete the kit
