Big Train James
It may not be so simple. I've been planning on doing both the inside and outside connecting straps on my p48 build. There is a fair amount of lateral movement in the wheelsets in the gear case and now I wonder if this will present a problem with straps on both the inside and outside of the wheel.Looks good, but now you have done the outer ones you really need to add the inner ones as well or it just won't look right. It is only 8 more pieces. Shouldn't be a problem with P48 wheels to space them accurately from each face of the wheels.
I'm curious whether the amount of slop is necessary? Is it a compromise to accommodate tight curves? Could I use some shims to reduce movement?I guess I'm worried that if the wheels are allowed to move, they may damage or knock off the straps and associated detail. I sure would like to have both straps per the prototype so I'll need to sort this out.
Dave, the new brake rigging is a tremendous improvement.
