Rippers
Ah yes. With figures being trialled and fitted now. Some areas of the layout do look like the site of The Millicent Street Massacre at present!The chaps in the builders yard have been in the pub for lunch, I note.![]()
That is most kind of you. I may be the models designer and I tend to be the one that adds the final finish and weathering to ensure some degree of visual consistency. But what you see is the work of several modellers. Amazingly a lot of what you see has been built on work benches mile's apart.Your model really is astonishingly good. It is entirely convincing in terms of the detail and colouring of each individual component. But the overall composition is also just right. Just superb.
Of course. No issue. This interaction is what the hobby should be about.May I ask what method you all use for making the windows on the various buildings please? Cut, etched or printed??
Thanks for the quick response.Of course. No issue. This interaction is what the hobby should be about.
The answer is pretty much all of the above.
We tend to be the sort of modellers that will use any material that will do the job and give us the look we want.
A few feature scratch built windows, but off the top of my head the backdrop factories use lasers cut frames, the block of shops/houses at the front uses some resin ones and the oval top lights in the electrical suppliers are custom etches.
The scratch built ones are mainly created from combinations of plastic strip, moulding and angles.The ones that are scratch built, did you build up from plastic strip, or card, or adhesive labels??
The previous photo makes it look like rhe red brick wall is next to the fish shop and there is no alleyway , that be trickery with smoke and those mirrory things .View attachment 208511
This might better explain how the Austin got where it did.
Cheers. The intention of the design from the outset it was the to create a period model of our local urban environment with the railway in it (rather than the more typical open view model of a railway with an urban backdrop). I dare say the deliberate restricted views of the presentation will attract criticism (as did aspects of the designs of both Walker Marine and Hospital Gates). But hey, it's our trainset.Hi guys,
I particularly like the way you look across backyards, round buildings to see the actual railway.
This is really progressing to completion now. Any plans for its first showing yet?
Kevin
"Still a way to go"...???!!! Wow!! What else needs to be done to it?? Looks amazing 'as is'!! To me, anywayA few extra details and a set of laser cut name boards are starting to add life to disused signal box.
Still a way to go though.
Cut the grass?What else needs to be done to it??
