Oh dear, past the 120 day mark again! Still. progress has been made, and I've now reached the point at which i can say, with confidence, that the whole ridiculous thing is going to work as intended! It's also starting to look like a 37 bogie now.
I've assembled the first bogie almost completely now - the sideframes need gluing in place, as do the end cross-members, but the whole ensemble is held together nicely by the spring pressure, and the location of the bearings in the axle guides, for the time being. The bogies moves freely, with the minimum of pressure, so I think that driving the finished loco is going to be interesting - firstly it'll have a fair bit of added weight in it to make the suspension work properly, but most importantly it'll have it's own inertia with the ability to coast.
A quick test indicates that I can run the bogie over an obstruction of roughly 2mm, and all wheels stay in contact with the ground, as demonstrated in the photos below:
[attachimg=1]
[attachimg=2]
The bottle of flux was just to add a bit of weight on the pivot, to make sure that it was an indicative test with a load, approximate to the final loco weight, on the pivot of the bogie. I'm quite impressed with the way that the whole assembly sits level:
[attachimg=3]
![Eek! :eek: :eek:](/styles/default/xenforo/smilies/eek.png)
;D
The motors need wiring up, and I also need to add pickups before starting to add the brake detail from the kit. Unfortunately, the method I've used to retain the motors in position means that I can no longer remove the wheels - a better piece of design work required there for the Mk2 version, still got to finish this set yet! An overview of the semi-completed bogie:
[attachimg=4]
It looks like it will be ready for inspection at the S7 meet at Mark - finally one of my elastic deadlines has been met!!!
