Landscaping . . part 1 ground areas
Richard Gawler
I have glued down my first scenic models, and so my groundworks give way to the landscaping. I haven’t used plaster for years, though I have used paper mâché and card surfaces. This is my first go with Sculptamold.
I will probably curse the water column for evermore, but I have to fix it now so I can fill in the adjacent ground surface. Offcuts of foam board to reduce the depth of the landscape formation (see later!)
I want the mature tree to be demountable so the tree gets a locating tube, a ply spacer and some mesh where its roots have raised the ground surface. I have shoved the sharp ends of the mesh downwards into the cork.
Three layers of card to make a profile, and more patches of foam board.
Cling film and masking tape, then the Sculptamold.
The metal mesh was good; the mixture dried out overnight. The foam board less so; and a patch 12 mm thick laid directly onto a cork tile even worse. These areas are still damp at the end of the third day. I suspect priming these surfaces with PVA was unnecessary (if well-intended) and it is certainly slowing everything down.
Patience.
Patience.
