Groundworks
Richard Gawler
I started to write about ballast here and on my Workbench topic but this was a bit premature. It is sensible to deal with the groundworks built directly onto the baseboard before adding any ballast.
I have made a start on these with the passenger platform.
I have made the transverse pieces in two parts. This way there is no accurate cutting needed except to get the outer ends square.
I overdid the depth of one kerf on the first front wall and it snapped. The second attempt has at least twice as many kerfs as I really needed. I got away with fewer cuts into the rear wall because the edge trim (below the cardboard finishing strip) is holding this piece into shape.
The platform will end up higher than I really wanted it to be, but this way the coach doors will open underneath the awning. The long lens has closed up the hoizontal gap between platform and lower footboard, this will end up about a scale foot. Passengers will use an upturned wooden box or portable steps to climb in and out.
The platform is a scale 64 feet long to hold two 30 ft coaches with a little leeway. I have used an entire 2.4 m length of 11 x 6 mm stripwood to build this.
When I glued in the last piece I thought about the fall (run-off) on the surface to let rainwater drain away. This would have been really easy to do with some packing under one long edge. On the other hand, the finished surface will probably be ash or gravel so no great need for this. And it will be easier to fix the building upright onto a level platform.
