Thank you Chris, I will try to keep going, and yes it is creeping ever closer towards completion, but sometimes it doesn't quite feel that way!
Last week was a bit slow going for me, so I only managed to get one layer of varnish on the cladding per day, despite the instructions on the tin saying "leave one hour between coats"! After the third, I decided to wait for another day before giving it a good rubbing down. I had intended to apply two more coats to finish, but covering such a relatively large, awkward area with so many nooks and crannies to work round, and using such a quick drying medium was a nightmare, so I gave up after the fourth! The end result is still a little scratchy and lumpy looking, but fairly well matches the much earlier, and now slightly worn saddle tank and dome!
Now it has all been put back together, at least there is no sign of the woodgrain underneath!
I have still got some touching up to do here and there with satin black on the backhead and fountain, including other spots where I didn't quite stay between the lines with the varnish. I chose not to use any kind of masking as I was applying thick coats by brush, and was rather afraid of creating some unsightly "steps".
In the meantime, I find myself somewhat caught on the horns of a couple of dilemmas - both entirely of my own making I hasten to add...
My own plumbing for the steam brake is pretty much spot on according to various copies of the drawings, but is clearly rather fulsome by comparison with both (NRM and NGRM) surviving prototypes, as well as photographic evidence. A shame really, as I have more than sufficient "reclaimed" pipe of the former diameter, but worse still, the only available next size down turns out to be noticeably too slender!
Taking into consideration a degree of vulnerability on the model, I think it might be the wise to just stick with what I have got... but I am still thinking about it?!
More of an issue though is my continued insistence on keeping the boiler, completely containing all of the electrics, readily separable from the underframes, and the mechanical drive parts. The overall design of the original, with just four angle brackets mounted atop the running plates lends itself to the principal, and by a bit of cunning, previously described subterfuge, various fittings and bits of pipework have been "attached" to the boiler structure, thus allowing a clean split. The only part so far that requires care, and has to be undone and taken down prior to a lift is the reversing rod on the left hand side of the engine!
I would like to keep it that way, but as you can see; there are two dangly little pipes (one still requiring it's brass fitting) that will be terribly prone to accidental damage during any future overhaul and reassembly operation. Not sure yet how best to make some kind of "invisible" solution?!
Pete.
