Work on the fiddleyard is nearing completion, cassettes completed and the fiddle deck attached to the layout with hinges.
At home, the fiddleyard encroaches halfway across the doorway when erected, so is simply dropped down on the hinges when not in use. When in the raised position it is supported by a removable prop, part of which can be seen in the photo.
For transporting the layout, the fiddleyard is detached by removing the hinge pins.
Power to the cassettes is transferred by the clips shown, which also align the cassette
The water tank has come in for a bit of weathering, and ye olde Airfix 14XX is doing sterling service on test runs.
The exit to the fiddlestick is very evident from this angle, taken from under the bridge.
