Courtybella Road (Western Region Mid 1990s).
Courtybella
Work on the layout has paused for a short time whilst I focus on a OO project; but I’ve had a mini side project on the go, the conversion of some HEA wagons into MEA box wagons as per the real wagons.
The first step was to remove the HEA hopper, straight forward just undo a few screws and cut the pipe work.
Remove the hopper mould from the chassis.
File down the raised lip on the chassis.
Measure out the floor for size.
Under floor support rib starts.
Ends measured, cut and fitted.
Sides fitted.
Basic shape of the box complete.
End and top rib supports fitted.
Wagon body complete, the underframe still needs some work.
Courtybella
Second MEA box coming along, I’ve decided to reduced the side ribs by one to make the spacing a little more pleasing to the eye.
Unless you know your MEAs the lack of one rib really isn’t going to detract to much.
I’m looking to eventually make up a rake of a dozen in mixed EWS, and Railfreight Coal colour schemes.
Courtybella
Going to call this complete, very pleased with this one managed to get the spacing and number of the ribs correct.
Now to production like the process, although it only took about 4hrs from start to finish.
I need to fit the air tank underneath, that’ll need a little support underneath on the under frame before the box gets a coat of primer then too coat.
Courtybella
The death of a HEA….
Complete wagon arrives for conversion.
Wheelsets, ladders and support struts removed.
Hopper body removed and pipe work cut clear.
Underside weight removed to allow striped underside to be sanded flush.
Completely striped under frame with wheelsets replaced - next up is sanding flush to allow a nice level fit of the box.
The pre fabricated boxes attached to the chassis ready for painting.
