Elmham Market in EM
James Spooner
After a few days on the roster it was time to return home and, having then caught up with tasks at home, I have again turned my attention to the Wickham DMU. I felt more in the mood for doing some metalwork rather than returning to the glazing so dug out my Dremel and a grinding disc and started removing the steps (which don’t match the position of the doors) and the trusses under the steps (which were present on the Derby lightweights but not on the Wickhams). I have managed to remove the extraneous parts from one side and will need to make good the grinding marks with some plastic padding before adding in the new footboards.
The photos show one side still with the full set of castings and the other with the bits removed.
Nigel
Jim smith-wright
Great stuff, dunno how I missed this. I'd consider replacing the power bogie though as it seems a shame to do such a good job on the rest of the unit to fill a quarter of the power car with a lump of metal.
This is a derby lightweight chassis fitted with a high level lo-rider
James Spooner
Hi Jim,
Many thanks for your comments and I have slowly been coming around to your way of thinking on the motor bogie. Your comment has prompted me to look at the High Level website but the Lo-rider doesn’t seem to feature there any more. I have emailed High Level to ascertain the position.
Nigel
ullypug
Hi Nigel
just spent a couple of hours reading through this thread. Don’t know how I’ve managed to miss it to date.
Some lovely modelling and a very atmospheric layout. Well done!
Dave Holt
The Lowrider bogies look to be designed very specifically to suit a couple of Mashima motors. As these are no lomger available, perhaps High Level have withdrawn them because no other motors will fit? Maybe, in time, Chris will modify the design around one of his coreless motors and reintroduce?
Might be wrong on this.
Dave.
James Spooner
Dave.
You are right; they are designed for the Mashima 1420 flat can. I dug one out from my stash before I realised that I couldn’t find the Lo-rider on the High Level website…
Nigel
James Spooner
The good news is that High Level have one Lo-rider left and are happy to sell it to me, so I will factor that into the build. I have made progress on the DMBS and all the glazing is cut and glued in. I think the next step is to complete the modifications to the underframe (which, I guess, will now be more extensive with the new motor bogie to be fitted).
Nigel
robertm
Nigel
You’re making a fabulous job on the Wickham railcar. It makes my efforts on my 7mm Met Camm restoration look really rough. Two questions if I may,
what material are you using for the cab windows and your secret for the snug fit?
what colour did you use for the roof ?
Thanks for any insight
Bob
James Spooner
Nigel
Bob
Bob,
Many thanks for your kind comments.
In response to your two questions, the window material is 20 thou PETG (often sold for use in dolls houses). It cuts quite easily and is protected on each side by a blue film that can be peeled off when you are ready to fit. The snug fit, I’m afraid, is good old fashioned graft. Cut roughly to shape then sand down with a sanding strip, test and repeat (and repeat…) until it fits. I use Micro Krystal Klear wiped around the inside of the window frames with a cocktail stick to hold it in place. I hadn’t got the patience to do that with the side windows (the sides are etched brass anyway, so much thinner than the 3D printed ends), so just glued the glazing in behind the sides.
To answer the second question, the paint is Precision roof dirt, airbrushed on.
Nigel
robertm
Thank you for your comprehensive answers. I’m only planning on using this method for the driver’s windows which are white metal castings. The sides are aluminium so the windows look fine just glued behind.
Thanks again
James Spooner
With the glazing complete I have added a bracket inside the inner end of the DMBS with a hole and a nut soldered to it. A hole drilled in the mazak underframe with a bolt through provides a fixing at that end. I have also ground off the remaining extraneous steps and supports and made good with filler. Then I added one of the corners in black plasticard and have now started forming the replacement footsteps out of scrap etched brass. A couple of photos show progress to date. That will be it for a few more days as I’m back up to Wales today, Snowdonian train tomorrow then four days driving before returning home.
Nigel
Dave Holt
Looks absolutely superb Nigel, and the weather's a bonus. I watched the loco change at BL and passing Harbour on the web cams.
Sadly, I couldn't take part this year as a major health issue prevented any forward planning and, as it turns out, I wouldn't have been fiit enough to travel anyway. There's always next year (I hope).
Enjoy the rest of your visit.
Dave.
David B
Looks wonderful - and I’m delighted that dear old Blanche was involved, despite being ready for her next overhaul (her cylinders still look well-attached to her smokebox with those chunky bolts which were such a pain to reproduce in 16mm scale). What a fabulous line-up of gorgeous motive power, first rate modern carriages and superb scenery. Thanks for sharing the photos - I think a battery R/C Lyd may have to be next on my workbench. As Dave says, enjoy the rest of your visit.
