Nigel
You’re making a fabulous job on the Wickham railcar. It makes my efforts on my 7mm Met Camm restoration look really rough. Two questions if I may,
what material are you using for the cab windows and your secret for the snug fit?
what colour did you use for the roof ?
Thanks for any insight
Bob
Bob,
Many thanks for your kind comments.
In response to your two questions, the window material is 20 thou PETG (often sold for use in dolls houses). It cuts quite easily and is protected on each side by a blue film that can be peeled off when you are ready to fit. The snug fit, I’m afraid, is good old fashioned graft. Cut roughly to shape then sand down with a sanding strip, test and repeat (and repeat…) until it fits. I use Micro Krystal Klear wiped around the inside of the window frames with a cocktail stick to hold it in place. I hadn’t got the patience to do that with the side windows (the sides are etched brass anyway, so much thinner than the 3D printed ends), so just glued the glazing in behind the sides.
To answer the second question, the paint is Precision roof dirt, airbrushed on.
Nigel
