Elmham Market in EM
David B
Fabulous! That train is living history, both ancient and modern, and it’s looking absolutely beautiful in the Snowdonia sunshine. I am very slowly starting to model the set in 16mm scale, beginning with two-tone Bowsider No 18. Despite having built dozens of carriages over the years, it is without question the most challenging carriage I’ve yet tried….but I’m sure the curly roof brake van will give it a run for its money in due course.
Looks like you’ve had a great week - thanks for sharing the photos.
James Spooner
Back home and after catching up on the garden as well as other jobs around the house I’ve turned my attentions to the DMBS underframe again. I have made up all of the footboards, drilled the mazak underframe (at the cost of several 0.5mm drill bits - I eventually worked out that the best way of tackling this little issue was to use a hand archimedes drill and fit the bit into the chuck as far in as I could) and fitted said footboards. Both of the rear corner extensions are also now in place and all of the bare metal has had a coat of primer.
Nigel
James Spooner
This project is now moving into its final phases. The pipework on the driving end of the DMBS is now painted and fitted and I have sprayed the underframe and bogies with some dirty black. That is both of the bodies finished and now the focus is going to turn to the replacement motor bogie, then the interior for the DMBS.
I have managed to secure a Lo-rider with an 8’6” wheelbase from High Level and will pick that up at ExpoEM. Construct that, design and construct a fitting to hold the bogie to the underframe and then work out how much room I have for the interior (which, to be fair, will be a lot more than the Bachmann design).
I have posed both ends side by side to compare them (and I think they are reasonably comparable) and taken a photo of the unit as it will look on the layout.
Nigel
James Spooner
I have been carrying out some long overdue maintenance on Elmham Market’s permanent way (resoldering some failed joints on the double slip, which is critical as it is at the entrance to the yard) and felt the need to carry out some tests. Firstly I carried out a thorough test of the new joints with the Liverpool St station pilot (history doesn’t record why it was so far away from its native haunts but rumour has it that it was on an RCTS special but the local shed ‘failed’ it…).
Whilst in the railway room I got the urge to try out the Wickham so quickly soldered a chip in and programmed it then had a play. It worked well, fortunately and the regauged Bachmann wheels coped fine with the EM pointwork. I also set it up alongside a regauged Bachmann Cravens DMU and I think it will pass muster at a layout level. Some photos of my playing this morning attached…
Nigel
Dave Holt
As you say, Nigel, it runs very nicely. Is that with the new HL LowrRider or the original Bachmann power unit?
It certainly holds up against the Cravens unit and adds a fairly unusual style of unit.
I've got a Cravens power twin converted too P4 using Branchlines wheel sets but never got round to fitting a DCC chip.
Dave.
Andrew Young
Today is my last day driving this week and it’s a gentleman’s light sporting turn, with the ultimate gentleman’s light sporting engine and a magnificent set of carriages in tow.
Nigel
View attachment 263267View attachment 263268
That is a fine set to play with! Do rather like a Gentleman’s Light Sporting Single Fairlie Loco, have recently obtained a suitable kit in 7mm scale to build. Only a week and a half before my next Welsh narrow gauge steam fix.
Back to the modelling, the Wickham DMU has turned out a treat, cracking model of an unusual prototype.
Andrew
James Spooner
Dave.
Thanks Dave. At the moment it is still powered by the Bachmann unit, the main problem with that being the amount of interior it takes up. My next steps are to collect the HL Lo-rider at ExpoEM over the weekend, make that up and work out some fixings to hang the underframe to it. When that is done I can make an interior for the DMBS and, voila, hopefully a completed DMU!
Nigel
James Spooner
Nothing in the way of actual modelling occurred over the weekend as I was stewarding at ExpoEM. I did however have several good conversations with friends, WTers and even people I had never met before, so very enjoyable from that perspective. I also managed to do some shopping for items that had eluded me and, of course, I picked up the Lo-rider kit from High Level.
Many thanks in particular to Geoff Haynes who, on the Sunday, gave me some personal tuition on use of lining with bow pens. I am sufficiently inspired to give that another go!
Back home and I have made a start on the Lo-rider. The etches go together really well. My difficulty is really trying to marry the kit to the Bachmann bogie frame. I have soldered up the basic Lo-rider ‘box’ and have since been hacking and slicing the Bachmann mouldings apart to try to get a fit. I haven’t succeeded yet and have given myself a headache so I think I’ll stop there for the evening and have another attempt when my head is a bit clearer in a day or so.
A couple of photos show the current state of affairs…
Nigel
James Spooner
Very little modelling over recent weeks as I have been more engaged in the full sized things as well as miniature live steam.
The weekend before last the memsahib and I had a long weekend in Snettisham for the final final weekend of running on the Norton Hill Light Railway. This is a 7.25 private miniature railway in North Norfolk and the line was opened by its owner on the Saturday for locals to raise funds for the local church. On the Sunday the Heywood Society visited and we ran a service for them, culminating in a double headed train with all carriages in tow.
A few days back home catching up on house and garden has been followed by a week in the TLC of Wales and now Yorkshire. Whilst in Wales the memsahib was finalising the 2027 brochure for Ffestiniog Travel and I did a number of different things for the Ffestiniog, including meetings, joining a track inspection walk and a day’s driving in the heat. Merddin Emrys returned to traffic last week as well after its ten year overhaul.
We return home today so hopefully I can crack on with the motor bogie over the next few days. A few photos of some of the bigger steam are attached.
Nigel
8d778b22-3a55-44d5-908f-ca347539bcd5.jpege94e8577-cf8b-4375-bd3d-ab6106ea6928.jpeg78def5c6-ddef-4a9f-a632-ce6368b3b243.jpegc1559795-6a11-49b2-810d-f46af1dd24be.jpegIMG_1630.jpegIMG_1635.jpeg
Andrew Young
Very nice, those 7 1/4 gauge locos look exquisite.
Good to see ME back, but what’s happened to James Spooner? Hope the curse of the brown engine hasn’t struck….
Andrew
