A pair of wagons for the new year, I’ve long fancied having a go at the BR(S) ferry open, and 3D printing means that I can have two in a fraction of the time I could build one.
These were found on eBay, deliberately from two different suppliers. One had separated out the various design elements which made taking the supports away and cleaning up a bit easier, the other more or less as one thing.
For whatever reason, the former was less stable and the body went distinctly wavy - I think the design is scale thickness for planking and perhaps thickening this up a few thou’ could have helped. The design, especially the axleboxes, was very fine indeed so I am happy enough. The chassis seems fairly substantial, so hopefully it will survive storage and a degree of temperature fluctuation, but I think that keeping these away from radiators is probably sensible.
Since one is to be sheeted, the solution is easy: a waft with the hairdryer and a solid box box of 60 thou’ epoxied inside. This comes almost to the top and should help ensure that it survives in traffic. The second one - in a slightly different resin? - seems more durable, but I’m doing something similar, hence the pegs. This one will have a load, probably MoD type crates with lift rings - I confess that I have no real idea what these got used for in ferry traffic but since the transfers from Cambridge Custom Transfers include all the markings it would be a shame to hide them, and such crates seem not to have been covered as a matter of routine. The idea is to do enough to fill another open at the same time, but we shall see!
Lots more on the go, with epoxy and Milliput the common themes, but more of that later.
