Interesting to hear about the different suppliers and the stability of the prints. I got some 3D printed plate and Medfit wagons from ebay, great models and nicely printed but they have bowed slightly after painting and adding weights underneath, I'm not sure what part of the process this happened. I used acrylic paints throughout and superglue and epoxy to glue the weights on. I'm not sure how or indeed whether to correct it.
I suspect that bowing is part of the nature of the beast unless designed carefully (and perhaps even then? The resins seem to vary hugely in their composition from the limited reading that I've done). A Plate is probably the most severe test: they're long, flat, and the sides offer limited torsional resistance to bowing. I think I'd stick to the Parkside/Bachmann or even Rumney options for one of those.
Moulded plastic can suffer from this, of course - the long bogie vehicles Cambrian do are a good example: mine are reinforced with bicycle spokes and that seems to have worked. Whether that would work for the printed equivalent, I'm not sure.
