Whew, what a day - as my wrecked knees will attest! Two newly aligned curves are now complete though!
Having laid the transition rails yesterday, and left the fresh "Postcrete" to harden overnight, I started things off this morning in the workshop by adjusting the bends of the first sleeper section, and re-setting them on the bench to make a new panel.
Then it was back down to the bottom of the garden to rake ballast out of the formation - sufficient to be able to lay out the new panel and mark the fresh alignment...
At least ballast laid over a membrane is relatively easy to shovel out to expose the original workings, and with the levels already established, shifting the "kerbs" was fairly straightforward, if a little tedious!
I tackled the outer alignment first, which then provided the arisings for immediate backfilling of the inner ones.
One particular, and much abused tool that I have found absolutely invaluable for this work can be seen laying in the lower part of the above image. A brickies' pointing trowel was doubtless never intended to be wielded by a railway navvie!
I was quite pleased with the rate of brick shifting progress, despite the heat of the day, but it was shovelling back the ballast, and re-levelling it that took it's time and exacted a toll.
The evening shadows were lengthening before I was finally able to fishplate up the length, and do a test with one of the genuinely "troublesome" trucks!
I have still got a few adjustments in the brickwork to do at the join between the path and sleepered section, as well as re-trimming the exposed edges of the membrane, but otherwise, I am very satisfied with the way it has turned out!
While it might only be a matter of an inch, or two, it doesn't half make a difference!
By great good fortune, the new radii curve will not only fit snugly between our boundaries, but has been arrived at by a nice and simple formula: The original outer rail radius is now the new inner, and of course, there is a new radius on the outer!
It not only "looks" much better... it works much better too!
Whew!
Pete.
