4mm Polsarrett: BR(S) N Cornwall Clay, The Final Countdown
Phil O
WOW, what was the capacity of that particular wagon? The load must be quite dense to require 4 axles on a 5 planker.
Mark F
It's quite interesting returning to modelling with a deadline in mind, having avoided doing that for my own stuff for the past few years. It's remarkable how many tasks can be completed in those gaps between meetings, waiting for the kettle to boil and at lunchtime; generally time I would spend doom scrolling through social media. Here's the output of the past couple of days of this renewed focus on modelling productivity.
The pasty wagon is, of course, a RCH 1923 spec end door open from Cambrian Kits, which mysteriously arrived on my doorstep on Sunday. As is often the case, a little remedial work was required to get things square and true, most notably the headstocks.20220328_135737.jpg
I'm try an experiment with the vee hangers; having first used them as a template to drill the solebars, on one solebar I inserted 4 lengths of 0.5mm plastic rod through the solebar and threaded the two vee hangers onto that. For the other, I soldered 4 lengths of brass wire to the inside face of one vee, pushed those through the solebar and then fitted the rear vee. On reflection, I prefer the latter method.
As you may already have gathered the wagon is getting etched brass axle guards, putting it all together for a dry fit, this is how far I've got.
So, having avoided deadlines for a while, I'm now setting my self the deadline of having this wagon, one other of the same kit and the four GWR O13s ready for paint by the end of this weekend.
PMP
Sorry to be the person to point this out, Paul - the brakes on the rechassised one are the wrong way round (I did this myself, a couple of weeks ago).
Thanks Adam, not the first time I’ve done it, and won’t be the last!
Re the diagonal stripe, the bodies I’ve got were seconds from a spares shop, and the livery was incorrect. On completion I corrected that but still missed the brakes!
It's having to mount them with the wagon upside down that does it, isn't it? Every, blinking, time...
Mark F
I'm glad it's not just me that struggles with getting brake gear on the right way around. A new one for me on these though; look closely at the pair of solebars above and you might spot that on one of them the vee hangers face upwards rather than hanging down - I can honestly say it's the first time I've made that particular mistake, probably won't be the last though.
Took me a while to see why it was upside down.
Easier to not get the V hangers upside down when the solebars are fixed to the wagon.
Peter Cross
As above it is easy to get them the wrong way around, but what I have seen and much harder to spot is the Morton brake levers on the wrong sides.
In other, not very exciting, news I had a delivery from MSE / Wizard today. Well, two deliveries actually, ordered 4 days apart but arriving on the same day.
Parts for the level crossing gates; enough round wire to finish the rodding, which I haven't started yet; finials for the signals; some etched signs; some brass rodding cranks; and some thin wire.
Tomorrow will be a trip to the printers to see if they have remembered to print off my backscene and layout name...
Perhaps a hair cut and order a suitable loud shirt for the show are in order too.
