Here we are again so well over a year into it but still not a huge amount of time invested really.
The cylinder block valve chest was completed.
Next up solder the crossheads and piston covers!
Didn’t go well not enough heat needed a bigger iron was the consensus on RMWeb.
After using brass rod and oil to keep things lined up went disasterously wrong! Didn’t think that one through, had to unsweat it and then used a cocktail stick as I had already seen but forgotten to do the same job.
This side went kind of ok but one slide bar was not soldered in proper.
Next tried the other side oh dear!
I’d already pulled 5e first side off but this was loads of heat to get the solder to flow all coming apart and moving around!
So 2.5 hours later it was all sweated apart cleaned and back together again.
So I dropped that idea and decided i’ll Make another coffee stirrer jig to make up the motion assembly.
Like a ladder shape stirrer with hole place piston cover on it cocktail point to locate, two more holes either side cocktail sticks in up to the motion bracket end another’s stirrer with tight clearance holes for those sticks to allow adjustment. Carve the stirrer out to allow the connecting rod to pass through drop the crosshead through place in the motion bracket and solder! Easy in my minds eye harder to explain. Then resin the piston cover on the front the cylinder block.
Not done this yet but that’s the plan.
So on to making up the crossheads and connecting rods I couldn’t bend the dressmakers pins for toffee but since found out I should of annealed them. I cut them and mushroomed the back over!
So first needed to set up the crossheads to gauge what needed to go where.
oh dear!
The crossheads bash on rear of the cylinder block. Possibly grind the rod clamp back. Wondered why Dave used a tube and they supports went inside! Know now..
Then I’ve got alignment issues the mushroomed pin and the previously filed crankpin nut clash one side and almost overlap the other! The better side is where I’ve opened out the piston hole as it was a bit skew, so this is perhaps the solution opening the cylinder holes until I get clearance.
Dave again was feeling for me here so kind gent he is sent me some new cylinder etches ones he had produced for P4!
Save me redrilling mine anyway here’s those!
What were the chances of that! Hey I’m a P4 man now!
So next a strip and soda crystal wash and rinse not been cleaned since it’s start.
So back together I noticed some old holes in the block where I had drilled them to wide, worth a shot to see if that width would work.
Kinda works so quite pleased doesn’t look crazy wide on the cylinder so Will go with it.
The school desk my work bench has been temporarily taken down while the train room starts in Ernest so nothing here probably till after Christmas.
But while I work on Barnstaple Quay signal box and station I’ll also have a do with this
Meldon Quarry
So as always all comments welcome
Until next time
