A final "Big Push" over the Easter Weekend has finally allowed me to get the remaining soldering completed on the body of the Barclay.
The seat units - on the real thing the seats tip up and have fore/aft adjustment by sliding along the axle
Installing the seats to a pre-tinned section of the cab sides - the dimples indicate the external rivets that hold the seats in place, so no excuses for getting the positioning wrong.
Some drilled lengths of microbore tube and some bent and flattened pins went to make...
...a couple of windscreen wiper motors. I connected them to the air system with wire to represent the tubing. (Note to self: remember to align the blades to match the actuators when you fit the wipers)
A similar lash up was made on the rear cab wall, with the air lines disappearing into and hopefully adding to the tangled mess of pipes making up the air system.
Air tanks temporarily in place - these are currently removable for painting.
Completed cab interior
I have replaced all the cast vac pipes with replacements from copper wire - the few hours spent replacing the part already included in the kit adding to the indeterminate hours of quite probably pointless effort already spent, but it keeps me off the streets.
The completed assembly.
The cab steps were assembled - the instructions list these as one of the first jobs, but I left them off in case they got damaged by the 3 years of pedestrian construction work (so far).
I also replaced the strengthening bar on the cab rear - the detail shots Bruce sent me clearly showed this riveted flat against the back of the cab. I previously had a thinner strip on edge. Close, but no cigar.
I had left the radiator ladder off the model to make painting easier, but the thought of this being attached with glue to paint didn't fill me with confidence for its durability, so I soldered firmly in place.
I believe this is the main air line from the compressor to the air tanks in the cab.
The underside of the footplate.
A happy modeller contemplating the possibility of finally dusting off the airbrush.
