Steve Cook
Well done Jamie, it looks like you have made a smashing job of that :)
Plastic might be a bit quicker to manipulate, but you started with a drawing, scratchbuilt just about everything and have seen it through to the end - you are a worthy winner as far as I am concerned. If I was wearing a hat, I would doff it in your direction!
Steve
jamiepage
Thank you, Steve.
I was going to put up this picture of S1409S being manoeuvred into the works as the end of the build. Unfortunately, on top of whatever work was scheduled, they will have to fit buffer heads and screw link couplings. Forgot all about them, so it's still not finished.
D816Foxhound
The last two days have seen a bit more airbrush action on my PMV, roof and undersides sprayed in "roof dirt" and "frame dirt" respectively.
It doesn't look like much has been done below sole bar level and I think I spent more time masking off the body than actually spraying the undersides. Next task is to do a bit of detail painting and transfers before weathering.
Roger.
D816Foxhound
Hello Steve,
Yes, the windows are staying blue. I substituted brass sheet for clear sheet as it made the painting stage a lot more straight forward.
And a bit of modeller's licence suggests that there was at least one PMV in blue without windows!
Roger
I have just spent three hours plus in the shed and have now got the vertical stanchions down one side finished. I have also removed the two wrongly placed diagonals on the same side. Unlike Steve I used the parts provided in the kit, which results in all the bolt heads more or less coinciding with the gaps between the planks:rolleyes:
Next up is to do the same for the other side, maybe tomorrow night.
I won't be building another.....
Nah, back to scratchbuilding.
This kit might have been OK when it was first done and in a smaller scale, but to be brutally frank if I were the originator I'd be buying back the artwork and either destroying it or sorting it out.
I'm going to finish the b*st*rd, but by today's standards its quite frankly a pile of crap.
Very many more have been purchased than completed, and based upon experience here a lot have made it into landfill along the way, which is probably the best place for them.
I am feeling a bit p:shit:ssed off with it as you can probably guess.
You are quite right Brian, my soldering skills are being honed as I chisel away at this monstrosity. I don't think this kit is that to which you refer, but then I believe there are very many other "challenging" kits available for those of us with a masochistic bent:confused:
Scratch building has never been easier....
Anyway, washing up done, tea made - I'm off out to the shed to do battle, accompanied by Radio Four Extra:thumbs:
Back from the shed, it's not pretty and it's not clever but it is progress.
All vertical stanchions on both sides now finished, window frames in on this side. Bit more cleaning up to do and I'm contemplating the door framing options. All end diagonals removed, options being considered here too.
Well, other side window frames now in, edges of door panels vertically "scrawked" to suggest shut line (nowhere near as neat as Cookie's elegant solution but sort of works), and all four door panels are now soldered in place on the body.
It's not getting any neater, but another small step forwards. It will get a bit of a clean up once I have finished soldering stuff.
Does anyone know what the bars behind the windows were made of, I'm wondering whether they were timber sections?
Simon, thanks for posting the photos. I now understand what you are wrestling with. The bolt head locations are certainly quirky. It should look good once you are finished but agree it would probably have been easier to scratch build, and more therapeutic.
D6356
Hi Bars behind windows were metal rods with a beaten end to provide two bolt holes - most fixed in with coach screws. I would guess dia of bar around 5/8". Say this as FR carriage works had loads in boxes EX BR/ NE stock ex Darlington and looking inside vehicles as a youngster at Bristol looked the same but do not recall if a PMV or GUVs got my look over in East dock.
Hopefully a full answer from elsewhere
Robert
Robert
On a lot of vehicles, yes, but not on SR PMVs/CCTs - as can be seen here: SECR, SR & BR(S) PMV NPCS Passenger luggage vans
I suspect, but don't know, that they were/are steel strip of two different widths. In model form some sort of flat strip does the job.
Thanks for the info, I'm pondering suitable materials in the model, probably timber or plastikard I think.
In the meantime I have now finished soldering this brute and am now heading off piste into plastikard and bodgery.
First off, here are my scribed door shut lines which I think actually work well enough for a minimum of effort.
You can see my home brewed solebar, required as I completely trashed the brass ones supplied in the kit. I did scrawk out two strips of etch brass etch waste which was epoxied to my styrene items to give them some strength.
The whitemetal axlebox/axleguards supplied by Ken are solid and a bit rough, and after damaging my fingers separating three of the brutes into constituent parts to allow springing with my Peter Korzelius axleguards, I couldn't find the fourth. Sanity struck me, I fished out some spare Slaters mouldings (they are from the milk tank wagon kit) and cut them apart and then stuck them back together with beefed up the springs, job now done for all four.
Next up is fabricating SR style axleboxes,one of the whitemetal ones is under the W iron.
And the buffers, those supplied remain a bit rough after cleaning up, I think I may use some Neil Butcher ones I have in stock, although they aren't quite the right pattern, both types seen here.
I may get some more done today..
Axleboxes now look more like Southern ones, just need three boltheads across their faces adding. Also now all formed up in to working units that slide up and down the Peter Korzelius W irons, and they are also fitted with ballraces. Still to be added are the functioning springs, I think there will be a slight issue of ride height to sort out.
I have also had to move a few of my rivet heads on the solebar and need to move a few more.
Back to the body next I think.
Steve Cook
Steady on old bean, you may be stealing a march here :p At least you've caught up now :))
You're still not tempting me to restart mine...
Steve
Thought I needed a spell in purgatory after this morning, so I have been concocting brake linkages around the wheels as best I can from photographs of the real thing.
Full piercing saw and etch waste lunacy and even then the geometry isn't quite right.
Good enough though, it's very hard to see any of this from any normal viewing angle anyway, but at least the brake yokes now have somewhere to go.
The yokes are plastikard fabricated around unbent paper clips, which are attached to these re-worked Slaters milk tank brake shoes. Whoops, the one on the left got a bit close to the soldering iron!
And a few weeks ago I started the home grown plastic door hinges, first set nearly finished.
Maybe I don't dislike it as much as I did, It'll be nice when its finished....
