That looks quite splendid Jamie
Well I managed a bit too.
After getting the Flymo running for the first time in over a year (it having had a bit of a service) the whole garden has been mown properly and looks a hell of a lot better for it. I did cut a couple of feed wires in the process though
I then made up a sensible power lead for my leaf sucker/blower with a cable and connectors I rescued from the tip a few weeks ago, and then replaced my two small Linolite strip lights in the shed (one of which was u/s) with a "proper" fluorescent tube, all properly fixed to the ceiling and wired in (I only tripped the house circuits twice in the process
The resulting lighting on the workbench is
much better than it has ever been, and more suitable for ageing fogey eyesight.
I then managed five hours (jeez) on the PMV but have as a consequence made some sensible progress on it.
All verticals in bar the door ones, all ventilator panels and hoods fitted all chalkboards fitted and ends attached to the sides.
The end diagonals very nearly connected with the corner angles, I may yet try a bit of bodgery with them in position but really they ought to be taken off and re-done.
Next up is to carve up the doors to yield all the 8 verticals that go either side of them. I may well use the supplied brass half etched flats for all the vertical angles (already fitted) but once the angles are sorted (and I need to fabricate some flat section for the bottom of the door verticals too) then I am probably mostly heading off piste with Plastikard
I do feel that I've now broken the back of it, but anticipate arriving at the finish line long after any spectators have gone home
