All to be cut into 10mm square roofing slates?
I must order some I need to make a coach.
Thankfully not Peter, just a couple of sheets of the 15thou. The rest is to restock.
That's handy. They've come pre-cut to the right size for the tiles.
Plonk 'em straight on.
Rob.
30 sheets in all. 10 of each 15thou, 30thou and 40thou. Quite a hefty package!
Hi Allen, welcome along.
Fingers are ok for model tiling. They took a beating yesterday though dismantling pallets to make some horse jumps.
Just out of interest where did you obtain them please ?
G
Ideal for "sending" my mountain bike over !
Still trying to work out from photos how the tiles in the valleys and sloping hip roof apexes were arranged.
The horizontal ridges seem to have red, presumably clay, half-bound ridge tiles but these are not apparently in other locations.
Any thoughts peeps?
Chris
From doing many hundreds of tons of stone on rooves, the old method was to lay the lead on the valley boards first. Or slates coursed up there. tiles would be taken right into the corner cut off at an angle. Sometimes slate was used under split instead of slate or lead under. The open valleys are quite recent, less prone to water ingress.
