The rear lean-to of the second wharf building has had some corrugated material added. Bog standard Wills sheet meant for 4mm but the sheets size at just over 2' wide and 6' long so fine for 7mm IMO.
All the edges have been thinned down though. No I haven't sorted out the joints and filler yet...
I'm thinking of a tired old felt and batton roof on the other rear lean-to. Experimenting with different finishes on areas of the buildings that will seldom be seen.
That does look nice. With my OCD I think I'd struggle to make a nice random state of disrepair like that.And the second side done...
and another one bites the dust - you just can't "un-see" it now.This is something I've never paid attention to.
Where are you going to try those Finecast sheets you bought at Stafford ?
That does look nice. With my OCD I think I'd struggle to make a nice random state state of disrepair like that.
and another one bites the dust - you just can't "un-see" it now.![]()
You've put them straight, but staggered. Would they be inline, but curved?
I used the "sticky" slates some years ago Chris and you're quite right, its a one chance to position them but definitely worth using if you don't fancy cutting individual rows.
However, if you really want to wear a modellers straight jacket then try some thatch a la "the Pendon way " !!!
I think some of you chaps may have seen this before but it certainly focuses your mind and dexterity.
G
So you'd recommend the tiles then?
Thanks matey, I'm not certain I would tackle it in 7mm but then ......That's very nice Grahame.Thankfully no thatch to do on Pencarrow!
Used them before, but in 4mm, on buildings for Damian's Diesels in the Duchy. The big long wagon repair shop in the middle of the layout and then the signal box both had them.
Thought I'd give them a go on 7mm and got 3 different types from York Model Making. The place to try them out was on buildings at the rear of the layout. They take a while to apply if you cut them into small sections. Depends what effect you're going for.
They are good but the plain tiles could do with some wider tiles adding to the sheet to do the ends properly.
I do like them but they aren't a cheap option if you're doing large areas.
Chris, if you intend getting any more it might be worth mentioning it to York Model Making about producing some wider slates on their sheets, you never know they could consider it.
I had a similar problem when I used them on a 4mm build but it didn't show as much.
