So, Chris, with those restrictions, how are you planning to actually use your Bulleid pacific? I know the ACE
was occasionally one BCK, of course, but quarts and pint pots come to mind.
Well, what can I say Adam...
The layout and fiddle was designed around the typical BR period length train that actually used Bodmin North and were in the general area (and within the constraints of room length). So we should be seeing:
- O2 or N Class or 8750 pannier and 2x Maunsell coaches to Wadebridge
- N Class or 1368 and a half dozen wagons
- AC Railbus
However that's a bit dull, and I'm only building an inspired by layout. So we'll also be seeing:
- BWT or 1368 or Class 03 on the clay line with a few wagons
- 8750 or small prairie or Class 22 on a B Set with a train to the GWR Bodmin stations
- T9 and 2x Maunsell or MK1 coaches to Wadebridge
Everything above fits nicely on the layout and in the fiddle yard. The plan is to run stuff in three periods,
1. BR steam with an ex SR bias
2. BR steam with WR infiltrations / substitutions
3. BR early diesel just before closure
However...
The Bulleid Light Pacific is my favourite loco class. At one point I had something like 60 of the things in 00, but these are slowly being sold off. So quite naturally, any movement to 7mm would also include a Bulleid, regardless of the layout constraints.
It's unlikely a 3 coach train will run on the layout, but at least now I do have a full 3-coach set. It's unlikely, other than posing for photos, that the Bulleid and 3 coaches will be seen on the layout. The loop is however long enough to run around 3 MK1 coaches.
As you say there was a stock balancing movement from Padstow that involved a Bulleid running with a single D2406 BCK. That could be seen and would easily fit.
Whilst the layout is being built for home use. I've also designed it to be exhibitable and in such case the home-use cassette fiddle would be changed to a longer ladder version. 3 coach train lengths could then be run.
In summary, having a Bulleid and 3 MK1 coaches may seem daft, but there is sort of a plan... Honest.
