You know, there are times in every build where you wonder why you ever started it. It came very close to one of those times with this build. The annoying part was I was so close to finishing it - I mean, it even had paint on for pity's sake! - that I knew I had to make an effort and at least try.
Or blame a house fire and give the client his money back.
Anyway, over the past couple of weeks I have been doing a spot of re-engineering. The third axle was extracted, the old Slater's 12BA crankpins removed and 10BA brass ones put in their place. I made my offerings to the goddess of epoxy resin (Araldite; like Aphrodite? Oh, never mind.) and set about tapping all the bushes for 10BA. And there things stayed for a spell, with the loco upside down in the maintenance cradle, various bits of valve gear carefully wired up out of the way, so the whole thing looked like some kind of game bird ready for the oven!
I knew the longer it stayed there, the harder it would be to make it go. Part of me wanted to leave it, because if I couldn't get the eccentrics to stay put I would be very disappointed in myself and would probably give it all up and go into a nunnery or something.
Well, today, that ugly, warty, fat old frog had my name on it, so I set to in a bid to consume it once and for all.
And there it is. The cranks don't keep unwinding, there are no tight spots or parts knocking, it blinkin' well works! Let the bells ring out and joy be unconfined!
While I was in a winning mood I refitted the various under-running plate parts that had been knocked off, fitted some new parts that were due their time in the sun, drilled out a hole for a self-tapper in the cab to the top of the firebox so that was all pulled up nice and tight without daylight showing, and fitted the backhead and the whistle. The top feed pipes were also slotted in. I think it's fair to say if anyone wants to disassemble this beast in the future, they'll need a lot of patience and some replacement parts!
Having exhausted the antacid tablets, and with the mortal remains of Nemesis the Frog scattered about the workbench, the next step is to retouch some bright metalwork, and get the loco back into the paint shop for a finishing top coat. After having sprayed the Lanky Tank with gloss enamel, I have been impressed by the strength of the finish. It will make a nice base coat for the weathering process eventually. Tomorrow, then, I shall probably be in the paint shop for a while.
I shall sleep better tonight, I think.
