Monks Ferry: a layout for the Grandchildren.
Happy New Year Jon, good to see all this coming together. I misread your post and thought you’d sprayed your grandchildren grey while the slept! I'm ok now the coffee is kicking in.…
Thanks, Jonski
And a Happy New Year to you too.
Jon
This is what I have in mind:
An extra track to the outside of the terminus was to be included to increase traffic, its source being via a curved turnout placed to the right of the outside curve (3rd radius) as you look at the plan. However, it risks stretching the width too far from the required 8’x4’ footprint.
Roger Pound
Just a thought, Jon - you could always model very early BR and the station canopy still awaiting replacement/repair following war damage by the Luftwaffe........could save a bit of work .:D;)!
Roger
Roger
Thanks, Roger.
That was the original intention with the Minories version of Monks Ferry, but I think in this version of events, I’ll just put it down to neglect ;)
The ‘tiling’ isn’t as onerous as it first appears once you get into a rhythm, and will help me kill a bit of time until I can start the carpentry.
Hope you like the plan.
Jon
I’ve made a start on the top tier.
First, the LCut Creative 7mm scale windows were cut - sides and bottom - to fit the space available, and render them somewhat proportionally similar to that of Blackfriars (a bigger Stanley blade this time eased proceedings somewhat), before fixing to the 2mm styrene sheet backing:
Then their widths were adjusted using sections of styrene strip:
Finally, they were dressed - as before - with watercolour paper surrounds:
Unfortunately, the paper bricks either sides of the gaps were disturbed while sanding, so I’ll remedy this with panelling (from more watercolour paper) similar to that of the ground floor.
In the pictures, the new section is unfixed and sits in the purpose created gap of the ground floor, which would have allowed its removal as per the initial idea. In this scenario it will be fixed in place, as the smaller - lighter - roof can ably sit on the pillar supports and still allow removal.
Now this part of the build has been achieved, I can gauge the rest from it, as there’s no drawn plan from here onwards.
I hadn’t intended to make a bulk purchase of track for the layout at this stage - haven’t even stock piled any wood for the baseboard yet - but unfortunately, a (fairly) local retailer was shutting up shop, so I struck while the proverbial iron was hot:
More will be required, as and when, but at least that’s the points sorted.
The scale of the build thus far is apparent in the following photo:
The platform side of the station building is shown seated upon the shelf to the rear of the main building, and dwarfed by the edifice to which it will be attached.
The letters of the former C.&B.R. (Chatham and Brighton Railroad), which amalgamated to form the latter S.C.&E.R., are apparent; like most early City lines, the railway was perched above its built environs on a viaduct, which will eventually involve me cutting out umpteen arches - probably from more watercolour paper- to form something like this:
John57sharp
Patrons has come back into modern usage, there could be similar entrances for members, subscribers and browsers. More seriously, it’s looking good Jonte and it’s good to see you were able to be en pointe with your purchases…
Coffee time!
Coffee time!
Patrons was the only viable option: not enough letters in the set for ‘Passengers’ or room for same ;)
Regarding the points purchase, I couldn’t help feeling as though I was somehow taking advantage of Hattons’ demise, but they really were too good an opportunity to miss.
Many thanks for your kind compliment and interest as usual, John; enjoy that relaxing cup of coffee :thumbs:
Jon
Pax = passengers
Canx = cancelled
Tx = transmit
Rx = receive
Wx = weather
The roots of these standard abbreviations date back to telex messaging and have been aviation industry standard abbreviations for at least 60 years - even before I started!
That reminds me: must dig out the old kite when the weather improves.
And remember, ‘always treat your kite like you’d treat your wo……’ (better not finish that line :oops: ).
Jon
Pax = passengers
Canx = cancelled
Tx = transmit
Rx = receive
Wx = weather
So basically abbreviate everything and add an "x"
